Is high performance coil worth it?
Old Nov 10, 2009 | 07:58 PM
rastoma's Avatar
rastoma is on a distinguished road
Default Is high performance coil worth it?
I haven't done any other mods to my Blazer, still trying to get it run 'perfect' (if that's possible).... still fighting a very slight surge on and off... also doesn't seem to have the power this size engine should have.
It has the stock coil on it.
I see a MSD's Blaster GM Coil at Oreilley's for $39.99 vs a standard OE style for $19.99.
If standard OE style wires are being used will a supposedly 'high performance' coil do anything for me?
Old Nov 10, 2009 | 11:16 PM
old skool luvr's Avatar
i had that MSD coil on my '92 Jimmy. didn't really notice much difference in performance, but my truck was stick, and i was always "foot down, rowing gears". i did notice that my plugs stayed cleaner than before.
Old Nov 11, 2009 | 04:28 AM
rastoma's Avatar
Are/were you running standard wires or 'high perf.' wires?
Sounds like for $20 difference it wouldn't hurt to get the MSD anyway?
Old Nov 11, 2009 | 05:11 AM
neo71665's Avatar
The factory coil is actually hotter than the engine needs anyways. If your coil is bad and you can get the MSD one cheaper than a ac delco then by all means go ahead. If not then just get the factory one. I'm running an MSD on mine and you won't notice a bit of difference, even with running the msd wires.
mcdevin1973
Oct 5, 2014 02:52 PM
blainenbecky
Mar 9, 2013 10:38 PM
chris015
Headers, Intake, & Exhaust
Jun 22, 2011 09:21 PM
Lancealot
Feb 22, 2011 07:34 AM
ivannj
Jan 14, 2006 11:41 PM
