Horn goes bananas when headlights turned on!
Old Feb 9, 2014 | 12:17 PM
richphotos's Avatar
What special tools for what?
Old Feb 9, 2014 | 12:22 PM
btb1003's Avatar
btb1003 is on a distinguished road
Nevermind. Helps to wear my glasses. I have a puller. Thanks for the quick reply
Old Feb 17, 2014 | 02:02 PM
btb1003's Avatar
Originally Posted by btb1003
I have this same issue (1994 S10 4X4) and when I turn on the hi beams the horn stops. I think it's the turn signal/hi beams switch. Let you know for sure when I change it
When this problem started the first symptom was the horn began to sound with the low beams on. BTW, it was random. I was sitting at a stop light when it happened. When I switched to hi beams it stopped, but the horn still functioned in the proper manner. I replaced the headlight switch on the dash and all began to work fine... for a while. About 6 weeks later I had the original issue recurr.
I procrastinated for a few months before addressing it again. By the time I had the hi beams were no longer working either. All I had were parking lights in front.
I removed the air box and the oil filter to gain better access to the headlight wiring. I saw a very corroded ground on the core support and bare wires from the headlight socket leading to the harness. Seems all that driving with hi beams and a bad ground will melt your insulation right off the wires.
I had good power off the harness main so I ended up rewiring all 5 wires off the pigtail socket. Been working great ever since. My 4x4 switch on the dash even works right now. Turns out the turn signal switch was NOT the problem, but a simple bad ground, just as richphotos suggested. Thanks Rich
Old Feb 17, 2014 | 03:43 PM
richphotos's Avatar
Glad you got it figured out, always start with the simple solution first. Can save time and money in the long run.
hollywoodgrad
Jan 25, 2012 01:58 PM
hotrodsbyg
Jul 3, 2010 02:37 PM
naf821
Aug 8, 2007 07:19 AM
bcw757
Jul 3, 2006 08:44 PM
quontush
May 7, 2006 11:16 PM
