Horrible Misfire/Idle Problem/Spark Plug Problem
Old Mar 29, 2007 | 02:48 PM
Daytripper540's Avatar
Daytripper540 is an unknown quantity at this point
Default Horrible Misfire/Idle Problem/Spark Plug Problem
The 1993 GMC Jimmy has been idling very very rough. When you crank it there is a very apperant smell of gas, the exhaust smells really bad, the spark plugs are covered in a black soot, and it gets horrible gas mileage. The exhaust is so bad that when you crank it and let it idle, the grass under the tip will turn black. It sounds like it has a big *** cam in it.
How do I fix this?
Old Mar 29, 2007 | 03:15 PM
Default RE: Horrible Misfire/Idle Problem/Spark Plug Problem
Sounds like either the catalytic converter has gone bad, or you have an internal fuel leak. Is this a CPI motor or TBI? I'm leaning towards an internal fuel leak, but if an internal fuel leak is allowed to go on too long, it will lead to converter failure.
Old Mar 29, 2007 | 03:54 PM
Converter has already failed and has been cut out. It's CPI, I think.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
Ron Snell
Dec 21, 2012 10:21 AM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
boulonman
Mar 5, 2007 05:10 AM
