how do i change a 94 4dr blazers fuel filter?
Old Sep 3, 2009 | 08:54 PM
classklown90's Avatar
classklown90 is on a distinguished road
Default how do i change a 94 4dr blazers fuel filter?
first off i searched this forumn and google and found no results. Im looking for step by step instructions on Locating as well as changing my fuel filter. I have a 94 4 dr, v6 blazer. I have never done this so I do not know how but i believe thats why the car is sluggish. thanks in advance
Old Sep 3, 2009 | 10:53 PM
rriddle3's Avatar
From AutoZone:
To locate the inline filter, follow the fuel line back from the throttle body unit or fuel rail. In-line filters are often mounted to the frame rail underneath the vehicle. It may be necessary to raise and safely support the vehicle using jackstands in order to access the filter.
  1. Properly relieve the fuel system pressure.
  2. Using a backup wrench (where applicable) to prevent overtorquing the lines or fittings, loosen and disconnect the fuel lines from the filter. Be sure to position a rag in order to catch any remaining fuel which may escape when the fittings are loosened.
  3. Remove the fuel filter from the retainer or mounting bolt. For most filters which are retained by band clamps, loosen the fastener(s) and remove the filter. For some filters it may be necessary to completely remove the clamp and filter assembly.
To install:
  1. Position the filter and retaining bracket with the directional arrow facing away from the fuel tank, towards the throttle body.
The filter has an arrow (fuel flow direction) on the side of the case, be sure to install it correctly in the system, the with arrow facing away from the fuel tank.
  1. Install and tighten the filter/bracket retainer(s), as applicable.
  2. Connect the fuel lines to the filter and tighten using a backup wrench to prevent damage.
Attached Thumbnails how do i change a 94 4dr blazers fuel filter?-0900c1528024fdb0.jpg
ryito1122334455
24
Jul 29, 2011 12:04 PM
busta_bird
Jan 11, 2011 04:38 PM
Vicer_Exciser
Nov 28, 2010 09:54 PM
kickme005
Aug 24, 2010 08:22 AM
azembdriver
Sep 23, 2008 08:00 AM
