How much timing advance do YOU use, 4.3 TBI & CPI How much timing advance do YOU use
Old Nov 5, 2012 | 11:57 PM
92cabby's Avatar
92cabby is on a distinguished road
Hi Guys,
I was reading your posts about distributor advance and want to pass along a trick I learned, about 40 years ago, from an old fleet mechanic. Take your car out on a nice flat stretch of road, get up to 50 or 60, keep it in its' highest gear, press on the gas to induce a load on the motor, but not enough to make it downshift. If it doesn't spark knock, stop and advance the distributor until it does. Then, each time you make a test run, stop and retard the distributor 1 or 2 degrees until it quits spark knocking. Then, retard an extra degree or two to get it just off the edge. If you keep it too close to the edge you may encounter a nuisance spark knock, if you get a tank full of lower octane or inferior gasoline. This technique worked really well on non computerized vacuum advanced distributors. Today it's a whole new ballgame.
G ELLIOTT
Oct 23, 2014 07:39 PM
wierdo124
Sep 2, 2013 07:38 AM
bigred01
Aug 6, 2013 10:48 PM
Bake
Performance & Brainstorming
Feb 4, 2012 10:31 PM
4x4VegasDan
Jun 19, 2010 10:54 AM
