i have no clue
Old Dec 6, 2008 | 05:44 PM
rattosh51's Avatar
rattosh51 is an unknown quantity at this point
Default RE: i have no clue 2 what is going on
The last link in the fuel system is the Fuel Pressure Regulator. There is a great writeup in the DIY section
on how you can check/replace it. That and the gas lines that go to the spider injector underneath the intake
are common failures that cause bogging/no power.
Old Dec 6, 2008 | 06:17 PM
What does "good pressure" translate to in PSI?
Old Dec 7, 2008 | 11:46 PM
green75's Avatar
green75 is an unknown quantity at this point
ive replaced fpr.i have a squeek comin gout of my distiburtor.
green75's Avatar
i have 60 psi
Old Dec 17, 2008 | 02:10 PM
green75's Avatar
whenits cold out i have to spray stating fluid to start.when its warm starts like a new car.changed evrything plugs distrib and,dc cap and rotor .plugs wires,put it on a scanner nothing is wrong.but runs like dog grap whent is codl?????????/
Old Dec 17, 2008 | 05:45 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Could try replacing the EGR or seeing if their is lots of build up in it, that causes terrible idle.
Old Dec 23, 2008 | 09:08 AM
green75's Avatar
i get it running and let it sit and warm up.check engine light comes on.codee 44.part store said it could be o2 sensore not sure.by they converter.i looked couldnt see is it buries up in there?
Old Dec 23, 2008 | 11:12 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
O2 sensor is in the exhaust pipe, pointed upwards, next to the tranny. Just behind the front wheel, iirc.
44 means lean exhaust detected - it could be the O2 sensor acting up or you really could have a lean condition.
CODE 44
Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin.
The conditions for setting this code are:
no Code 33 or Code 34 (MAF Error) present, and
the O2 sensor voltage remains below 250 mVolts, and
the ECM is in Closed Loop control, and
the above conditions exist for more than 50 seconds.
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) MAF sensor reading lower airflow than is actually present
7) Vacuum leaks
8) Incorrect or poorly calibrated PROM
Old Dec 24, 2008 | 07:46 PM
green75's Avatar
yesterday ran like garbage.it was cold out 19 degrees.today it was 54 and it started by itself no starting fluid needed.does this make sense?
Old Dec 25, 2008 | 08:41 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
If you have a good scan tool available, have yourself or whomever check at cold startup the coolant sensor(SENSOR) that reports to the computer. I have had one or two of these in my lifetime where that was the issue and the results were exactly as you said. Keep in mind that there are two(2) coolant sensors...persase...one for the dash and one for the computer so...if you were to say that the dash reads correctly that does not pertain to what I'm stating. Probably not going to be lucky enough that this is going to be it but worth a try. But, you have to have a scan tool that reads this sensor or I guess you could pull it and ohm it out but much easier to scan it and have a look! JP
