i pulled some codes
Old Dec 7, 2009 | 11:57 AM
flipzat's Avatar
flipzat is on a distinguished road
i pulled a 67,81,82
on http://www.troublecodes.net/GM/94-95_43W.shtml it says
67
Torque Converter Clutch (TCC) Solenoid Circuit Fault, pls tell me what i have to do to fix this also could it cause the truck not to start / stall?
also my remote starter look like it spliced into the ignition coil purple wire spliced into a white one
stupid questoin i bet but where is the The Torque Converter Clutch (TCC) solenoid circuit
Last edited by swartlkk; Dec 7, 2009 at 12:31 PM. Reason: Combining Consecutive Posts - Please use the EDIT feature to add additional information to your post if another member has yet to respond.
Old Dec 7, 2009 | 12:33 PM
A TCC code should not cause your truck to stall. I would be looking into the grounds in your truck. All of those transmission codes likely are related. Look at the grounds on the back of the passenger side cylinder head.
flipzat's Avatar
would a code 67 cause a code 81 and 82?
thanks im going to give it a look, my truck wont start and i pulled those codes was wondering if the issues are related
Last edited by swartlkk; Dec 7, 2009 at 12:44 PM. Reason: Combining Consecutive Posts - Please use the EDIT feature to add additional information to your post if another member has yet to respond.
Old Dec 7, 2009 | 01:11 PM
flipzat's Avatar
i went out to look and i could not find this ground is it hidden or hard to see what does this ground to ? sorry and thanks for help also where is the grounds for the tcc ? is the a fuse or relay for this ?
Old Dec 8, 2009 | 01:17 PM
flipzat's Avatar
thanks for help guys i fixed it i replaced ignition modular and rotor that made it start and run hella good
also i tested for codes again and got none :?
Dano01
Dec 4, 2010 01:52 PM
dlippiet
Oct 7, 2010 10:36 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
