IAC and identification
Old Feb 6, 2018 | 02:19 PM
Lefet's Avatar
Lefet is on a distinguished road
Default IAC and identification
So I finally got to the IAC sensor today. Didn't really seem as though I did much. I sprayed it with carb/choke cleaner and put it back. I'm not sure if that plunger is supposed to move or not but it didn't budge. There also didn't appear to be a lot of sludge built up on it. The Haynes manual I have said replace the gasket, but there wasn't one. Should there be?
Also, while looking around, I found these two connections. Any idea what they go to?
Attached Thumbnails IAC and identification-20180206_143353.jpg   IAC and identification-20180206_143339.jpg   IAC and identification-20180206_143323.jpg   IAC and identification-20180206_141942.jpg   IAC and identification-20180206_141920.jpg
IAC and identification-20180206_141909.jpg   IAC and identification-20180206_141822.jpg
Old Feb 22, 2018 | 01:04 AM
Lefet's Avatar
Anyone with any idea of those two connections?
Old Feb 22, 2018 | 02:59 AM
Rusty Nuts's Avatar
By their size, number and location I'm guessing ABS connections. The larger red and black would go to the motor and the other for the module. They look like they connect on the top of the module.
Old Feb 22, 2018 | 03:23 AM
Lefet's Avatar
That sounds like something I would need isn't it? Would the ABS system not be working properly if they weren't connected? Thanks for the response by the way.
Old Feb 22, 2018 | 03:57 AM
Rusty Nuts's Avatar
Correct. The ABS light means the system is not working and the wheels will lock up. They may have been unplugged to make the light go out.
Old Feb 22, 2018 | 11:32 PM
Lefet's Avatar
Thanks Rusty, they have locked up twice and I skidded, but I assumed it was due to the severe ice condition at the time. Guess this is something I'll have to put on my "to do" list.
Thanks for the input, really appreciate it.
Old Feb 23, 2018 | 08:49 PM
They're referring to that o-ring.
Old Feb 23, 2018 | 11:25 PM
Lefet's Avatar
Thanks, thought so.
Old Feb 24, 2018 | 06:42 AM
newguy's Avatar
Yes the plunger should move in and out
Old Feb 24, 2018 | 04:36 PM
Lefet's Avatar
It didn't budge, it did spin, but no movement up/down, in/out. My manual also mentions something about measuring the one you take out as the depth of the new one should be the same. I didn't see where this one would adjust any. Should it?
