IGN/GAU fuse trouble
Old Feb 9, 2011 | 01:53 PM
ghero86's Avatar
ghero86 is on a distinguished road
Default IGN/GAU fuse trouble
Why would it put out more than 30 amps when the fuse is suppose to be 20?
Old Feb 9, 2011 | 01:57 PM
Shorted circuit?
Vague post == vague response! Details man!
Old Feb 9, 2011 | 02:38 PM
ghero86's Avatar
Default more info
i thought there was an automatic transmission problem, so i changed the transmission oil and added stop slip because it was slipping a bit.
when i checked the fuses, i noticed the ign/gau was bad, put another one in and it popped right away. I tested it and it said it was putting out 36.5 amps. i noticed that the transmission fluid was low so i filled it up and took my blazer to get more fluid and it died in the parking lot, i had to get jumped four time to get home, got the alternator test and replaced.
Old Feb 9, 2011 | 02:45 PM
And you are driving?? Year, model, options (trans, drivetrain, etc)??
Old Feb 9, 2011 | 02:54 PM
ghero86's Avatar
1994 s 10 blazer v6 4.3L auto 2WD
Old Feb 9, 2011 | 03:02 PM
Here's everything that is powered by that fuse. You could have a problem with one or more of those components and/or a wiring issue between the fuse and any one or more of those components.
Attached Thumbnails IGN/GAU fuse trouble-94_ign-gau_fuse.gif
Baja Blazer 85
Oct 15, 2012 06:02 PM
1991chevy
Oct 11, 2012 12:53 AM
ncpi
Oct 12, 2011 09:17 PM
crags
Aug 9, 2009 08:04 PM
The Slacker
May 26, 2008 07:00 PM
