Installing Trailer Lights HELP PLEASE
Old May 16, 2009 | 04:49 PM
blazermayne87's Avatar
blazermayne87 is on a distinguished road
Default Installing Trailer Lights HELP PLEASE
EDIT: This is a 91 chevy s10 blazer, 2dr, 4wd, 4.3ltr z vin.
I am installing a 4 flat trailer light plug. I either need a wiring diagram for the tail lights or help on which colors to attach to. (The right side says green wire, but there are 2 green wires, one dark and one lime) The left says the yellow, and there is luckily just one yellow. White is ground (figured I would just ground to the frame, but there is a pre-existing white wire in the bunch) If anyone can help me on this, it would be great!
Thanks
Steve
Old Jul 13, 2009 | 12:35 AM
mhollis's Avatar
mhollis is on a distinguished road
Basically you just match up the colors, yellow to yellow, dark green to dark green, and the white in the bunch is a ground wire as well. so you can use it or just ground to the truck.
Old Jul 13, 2009 | 02:15 AM
bandidolenny's Avatar
Green = right turn / brake light
Yellow = left turn / brake light
Brown = tail / running lights
White = ground
As you look at the flat four wire harness the colors should be Green/Yellow/Brown/White in that order.
Philipx
Dec 14, 2015 04:29 PM
geo
Dec 6, 2013 07:05 AM
phxjosh
Dec 1, 2013 06:28 PM
AndrewO1991
Feb 19, 2013 03:52 PM
ABSLT
Dec 13, 2011 09:28 PM
