Interchangeable "dash&door" !!help!!
Can anyone help me out with a qucik answer
im looking to change my driver side door i have a 2 door 92 blazer does anyone know if i can swap it out with an 88 & is it a direct fit ? Plz and thanks in advance i apreciate any help
ALSO CAN I PUT AN 85 DASH IN MY 92 ?
I can't imagine why they wouldn't fit. I am not aware of any mid-generation changes to the door area. The 85 dash would likely be older looking so not sure why you would want it but if you are swapping everything including gauges, what would be the issue? On second thought, the gauges could easily have a different wiring harness so that could be an issue...
Dash wont fit,cant remember why but someone already tried and said it wasnt a drop in swap..
Door panels from a 88 should fit,as long as you swap power window etc with power window. or manual with manual.
kyle.c
Oct 17, 2010 01:11 PM
