just got an 87 s10 please help!!!!!!
just bought an 87 s10 blazer 4x4 and its got a bad shake in it... when its ideling or driving anytime except when its in gear stopped... not SO bad.... any ideas? please help or links to simalar problem and fixes, thank you
RE: just got an 87 s10 please help!!!!!!
I'd say plugs and wires need to be chekced first thing. I'd do a complete tune-up on it. Are there any codes or lights coming on? Maybe you need to clean up the EGR? No stalling at all?
previous owner said plug, wire, cap, rotor, and fuel filter were all new 2-3k ago.... sometimes slight hesitation when taking off from stop
i had same problem w/ my 92 blazer, i replaced the thermistat and that fixed the idleing problem, ur sending unit might be bad if its hesitating to go for a second when u hit the gas, my fuelpump and sending unit was the problem on my truck...
Pull one plug and make sure it has the correct gap. Improperly gapped plugs will make the engine run rough, espeaically at lower rpms.
