Left Turn Signal Problem
tonight i noticed when i went to drive i turned on my lights and noticed my left turn signal indicator stayed lit and i turned the left turn signal on and it did not work so i check the right side and it works fine and then i turned on the hazards and all turn signals started blinking and they all worked.
But i still cannot get the left side to work with the turn signal it self and it stays lit even when i don't have it on but nothing happens while the indicator is lit like that.
I did some research for a bit and seen something about a turn signal flasher could that be the problem?
check the turn signal bulbs
You have a bulb out... There is 2 bulbs in the tail light assembly... make sure they are both working when activating the brake light circuit.
Yeah all bulbs are good just checked them all
Flasher assembly, they are like 8 dollars. To find it, turn on the signal that blinks, and get down by your pedals and find the thing thats clicking. Put your hand on it to make sure you got the right one, the other ones for the 4ways.
Yes, that is a flasher but that's kinda pricey. This is what is in mine and it works
http://www.oreillyauto.com/site/c/detail/BUS0/552.oap?year=1994&make=Chevrolet&model=S10%2BBlaze r&vi=1060591&keyword=flasher-hazard+warning!s!turn+signal&forcedVehicle=true
Ok thanks man
JBLAZE
03-15-2008 05:21 PM
Jimonawing
11-16-2007 02:38 AM
scottvwcars
12-29-2006 08:46 PM
