liftgate wont open
I have an 87 s10 blazer and just recently I've had a problem with my rear liftgate. I can pop the rear glass just fine but I can't open the liftgate, the handle just keeps spinning around the lock cylinder. I haven't figured out a way to pop it manually. If you have any suggestions or have had the same problem help would be greatly appreciated.
Thanks |
You have to pop the access panel off from the inside. Then you can just grab the bar on each side and pull them inward. I been opening my gate for years like that
How do I do that though, I can't open the liftgate and the screws are below the floor line?
i jus ripped mine off. i had the same problem and i also have no idea how to change that dang handle to open em
