my blazer has STARTING problems
my 87 blazer wont start until it turns over for 15 seconds? i changed the relays on the finder thanking it was a fuel pump relay but i noticed that it starts up after the oil pressure gauge moves to 15 psi or if i give it a shot of starting fluid. after it starts it runs fine???????????? any HELP OUT THERE 2.8 auto matic TBI
It could be a faulty oil pressure sending unit.
My '87 2.8 S10-Blazer has two diferent oil pressure sending units. Most repair manuals show either a 1 wire, 2 wire, or 3 wire unit. I have a 2 wire & a 3 wire units. The oil pressure sending units are located next to eth oil filter. Take a look at your and post up what oyu have.
Take a look at Autozones web site. They have wireing diagrams for our trucks on line.
This is quite inlikely, but its a cheap fix, and its easy to check. If you live in a cold environment, and some moisture got into your distributor cap, it may have frozen, expanded, and cracked it. It is held down with two screws, and it costs less than ten bucks. Just take it into a dark room and put a flashlight under it to see if there is any light coming through where it shouldn't. Its a long shot, but its cheap.
ussexplorer
13
Jun 2, 2015 03:04 PM
bertrenolds
Mar 28, 2012 09:59 AM
tsLongarms
17
Aug 20, 2011 01:55 AM
Philly Assassin
Jul 24, 2007 11:57 PM
