My windows and cruise don't work
Is the first thing to check: Fuses?
NONE OF the windows work, from any control. Power windows. 94 Tahoe LT. Also, cruise does not function.
Since Dash was apart, I suspect something either disconnected or left unplugged.. please help me on a step-by-step, proper, dig of these issues that MAY BE related.
I am questioning the power output of the switch, unless I am doing it wrong.
I am holding the lead on the negative (black) wire, and touching the other 8 connections, 0V seems to be the result. (It is my understanding that with a digital multimeter, polarity doesn't exactly matter, worst that can happen is a negative reading of the same number.)
The jumper cable thing was also an attempt at creating "ground."
Sorry for the delay in reply.
This is where I am at so far.
I wonder if the Chevy dealer will have an OEM switch, for a reasonable price.
In any case, I am about to find out, and get a switch, of any kind...
From my Youtube video (my other Youtube video
ur making it so dam hard. put the phone down, take the connector off the motor itself and check for voltage at the motor connector key on and switch upper LEFT depressed. the upper left is the driver side. no voltage = wiring. if you get 12 volts or close then its the motor. simple as that. takes 2 minutes.
