Name this vacuum/vent hose...
Old 10-27-2013, 09:11 PM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Default Name this vacuum/vent hose...
what is this hose and should it have vacuum on it? it does if I hold my thumb on it at warm idle.
Attached Thumbnails Name this vacuum/vent hose...-image.jpg
Old 10-27-2013, 09:25 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
do you still have your vacuum ball on the passenger side? if its not plugged up,thats your hose which has been cut.ive got a 93 vin w. tryin to remember whats all on that side.
Old 10-27-2013, 09:48 PM
Yep its there, but it already has a hose hooked to it just like this one. I was thinking this may be the front diff vent, but the vacuum it was drawing threw me off.
Old 10-27-2013, 09:50 PM
chris015's Avatar
its definitely not the diff vent. Look behind your engine,passenger side of the distributor. you'll see a T,and a bunch of lines etc that plugs into your manifold. any capped off or missing?
Old 10-27-2013, 10:03 PM
There is a tee off the back of the manifold. It has four small hoses coming off of it. None plugged or missing, haven't traced them all out yet, got stuck on this one.This all started looking for the cause of rough idle of course.
Old 10-27-2013, 10:18 PM
chris015's Avatar
the leak can cause the bad idle...For now id just stuff a screw in it.
Old 10-27-2013, 10:27 PM
I'll try to chase it out and see where it ends. when I put my thumb over it it draws a really slow vacuum, unlike the brake booster hose that can give you a pretty bad red spot. I've searched diagrams till I'm cross eyed and had no luck identifying it yet.
Is there anything else on the passenger side it could go to?
Old 10-28-2013, 08:18 AM
chris015's Avatar
i dont think so unless you have 4wd.
I'll take a look at my 93 today and see where everythings routed.
Old 10-28-2013, 09:26 AM
It's a 4WD. I'll update my sig.
Old 10-28-2013, 10:36 AM
chris015's Avatar
do you have a vacuum line running to your 4wd actuator under the battery tray?
Quick Reply: Name this vacuum/vent hose...
