Need Electrical Help
Here's a step by step to check the coil & ignition mod on a GM 4.3, 5.0. & 5.7 engine.
Part 1 -Ignition Control Module (ICM) Test: GM 4.3L, 5.0L, 5.7L.
You can also go to You Tube, plenty of vids on testing a coil using a spark tester.
Thank you again
When I connected the black lead of the LED test tool with the red lead attached to Battery (+) terminal the LED light came on and that was with the ignition switch off and then when I turned the ignition switch to on position the light went out and didn't flash. I even tryed it with the Lead going to the Ignition module disconnected the LED light still stayed on.
HELP!!!!!!!!!!!!!!
JoSHN
Sep 14, 2012 04:56 PM
RomanCatholic
19
Oct 26, 2009 03:10 PM
mudd4
Nov 22, 2008 02:03 AM
t_money_nwa100
Oct 4, 2007 04:05 PM
