need help
Old Mar 23, 2008 | 11:47 AM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default need help
rear window defroster does not work need help locating the relay and fuse for it tired of rolling windows down to defogg the rear window help
Old Mar 23, 2008 | 02:39 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: need help
the rear defrost wires on the window could also be burnt out or broken. idk where the relay is for it i would check in the fuse box tho that is under the dash on the driver side. try checking the system with a meter and see what u get. kyle should be in to comment too he's good at this stuff also
Old Mar 23, 2008 | 02:58 PM
If the wires are burnt out how should i re wire them so that would work properly
Old Mar 23, 2008 | 03:12 PM
to tell if its actually burnt out use a test light and go along each wire from the positive end to the negative end (not sure which is which but when u use it u'll see) and the light will stay bright if it works and when it goes dim or out thats where u have a burn out or break. they make a kit to repair these. the kit is cheap. im not sure what its exaclty called but something like rear defogger repair kit. u should be able to find it at any local parts store like a napa or autozone. in the kit its a type of soder that u "paste" on to renew the connection.
Old Mar 23, 2008 | 03:23 PM
sry it repeated
Old Mar 23, 2008 | 03:25 PM
sry it repeated again
Old Mar 23, 2008 | 07:49 PM
First thing I need to know is what you are working with... Year is a bare minimum... Please include this information in your signature so we don't need to ask.
1hugeblazer
Feb 21, 2011 06:05 PM
maximashift
Nov 17, 2009 09:36 AM
maximashift
Nov 17, 2009 09:33 AM
blazin4eva
Jan 27, 2005 02:02 PM
