Need Help
Old Nov 28, 2010 | 07:12 PM
Schmidty667's Avatar
Schmidty667 is on a distinguished road
Default Need Help
I have a 93' Blazer, I have an issue where when cold and Idleing my truck sounds good. When it warms up if runs rough like it is miss firing. I have timed, Replaced: router, cap, wires, plugs, spider injecters, O2 sensers, fuel filters. Have checked the compression on all cylinders and it was good. Fuel pump was tested and had good pressure. I am stuck I don't know what to do from here. Any suggestions on something to check where and how is much appreciated.
Old Nov 28, 2010 | 07:16 PM
*Moving to 1st Gen Tech* - As the description of the Gen Chat section states, technical questions belong in the appropriate technical section.
Is EGR valve functioning properly, not leaking?
When the fuel pump was checked, was the leak down rate monitored? You could have a leaking FPR.
Old Nov 29, 2010 | 08:58 AM
How do I test the EGR valve to find out if it is malfunctioning?
1hugeblazer
Feb 21, 2011 06:05 PM
maximashift
Nov 17, 2009 09:36 AM
maximashift
Nov 17, 2009 09:33 AM
blazin4eva
Jan 27, 2005 02:02 PM
