Need Ignition Help
OK Friends I need somemore help!!!!!!
I Have a 93 S10 Blazer with 4.3 Vortec (W) enigine that has no spark.
I have 12V at the Coil and tru to the Ignition Control Module. I also Tested the Pickup and while turning over the engine it was giving me .5volts.
I then tested for Ignition Coil Switching Signal with an LED test tool there is where things just don't add up!
with the red lead from the LED tester on + battery post and black lead on the white lead from the Ignition Control Module the LED is lit but once I turn the ignition switch on the light go's out. and when I crank the engine it dosent light up at all.
Can you tell me what is bad? LOL
PLEASE
PLEASE
Brian5792
10-24-2018 11:34 AM
eastsiderides
08-14-2009 11:58 PM
vin791
11-26-2008 09:07 AM
5k5s
02-02-2008 10:45 PM
