Need serious help please!!
Old 09-12-2012 | 11:18 PM
tlw221's Avatar
tlw221 is on a distinguished road
Originally Posted by japking
So you're driving and it just dies out of the blue?? My problem ended up being the timing being off. Could be a map sensor. Be more descriptive on the symptoms.
Yeah it just dies out of the blue and then won't crank back unless I spray starter fluid in the intake. And even now I can't drive it bc it doesn't stay cranked but for about 2 seconds. The only time it stays cranked longer is if I keep my foot on the accelerator. And if its a sensor wouldn't it be throwing a code?
  #22
Old 09-13-2012 | 09:46 PM
ohsofly's Avatar
Once again... Diagnose the CPI INJECTOR LEAK
THE FUEL SYSTEM HAS NO SENSORS. So a runability issue with no codes is most def fuel related
  #23
Old 09-14-2012 | 08:14 PM
tlw221's Avatar
Well replaced fuel pump last night and still nothing! So every part of the fuel system has been replaced and still nothing is working. I don't know where to go or what to look at. Could it be a ICM, crank sensor, or the pick up coil?
  #24
Old 09-14-2012 | 11:02 PM
ohsofly's Avatar
Nope, all those would trigger codes. Its fuel related.
I want you to jiggle around the red/blue wires that come out of a gromet in the lower intake, under the throttlebody. Those power the injection unit and have wires in the connector thin as hairs. The rubber insert in the plug that is inside the connectoe itself is a known problem after 20+ years. Mess around tugging and pushing thoae wires and see if you get any difference... You are gonna kick yourself if this is your issue, its an 8 dollar part!
And for gods sake stop wasting your money throwing parts at the car.
If you really want to spend money wisely, get yourself one of these... This will show you a leak for sure.
http://item.mobileweb.ebay.com/viewitem?itemId=180970058851&index=3&nav=SEARCH&ni d=35521485428
And this is how it is used.
http://www.youtube.com/watch?v=fdlUzSLRdao
Bigmancason
06-23-2011 03:23 PM
Doverman454
08-15-2010 12:46 AM
lionel2
31
03-14-2008 10:58 PM
mike1970
04-12-2007 11:21 PM
bowanna03
10-01-2006 04:10 PM
