No air coming from vents
Okay I've done some searching and seen that these two issues come hand-in-hand apparently.
[ul][*] Hissing under the hood.[*] No air from the vents.
[/ul]
Okay it seems to me that the hissing is coming from some place near the distributor cap. That and I have no air OR heat coming from the vents on the dash. It comes from the floorboard and the defrost vents though. I've checked the plastic ball-shaped vacuum pump and line it seems fine to me. No holes or leaks anywhere that I know of.
I drive a 1994 2WD GMC Jimmy VIN W. Anyone have any good ideas or suggestions?
[/ul]
RE: No air coming from vents
You are not getting proper vacuum supply to the HVAC system. The hissing indicates that you have a vacuum leak which is what is causing the HVAC problems.
check the hose that comes off the back of the plenum and goes to a 3 or 4 or 5 way connector-bet you have no cruise either. jp
ORIGINAL: swartlkk
There will be a small black hard vaccum line that runs into the cab right around the dizzy, make sure its not broken, cracked, or missing and still hooked up.
Some carb cleaner or an unlit propane torch make for the best vacuum leak finder. With the engine running, trace along all of the vacuum lines until you hear a change in the idle speed/sound.
Soap won't do anything as it is engine vacuum in these lines, so it is pulling air in...
ORIGINAL: swartlkk
Bobcat13
11-06-2013 02:21 PM
RomanCatholic
16
09-01-2009 10:47 PM
