no fire on 91 blazer
Old Dec 27, 2008 | 10:35 PM
daroach1's Avatar
daroach1 is an unknown quantity at this point
Default RE: no fire on 91 blazer
Ill update tomorrow afternoon. I am going to check the timing. How does timing become advanced if there was never any movement of the distributor? Failing cam or timing chain?
Old Dec 27, 2008 | 10:41 PM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
Possibly a worn gear on the distributor, loose dist hold-down, cap replaced in wrong position, wires ran wrong... thats about all that could happen.
But if it has severly advanced timing, it will belch through the throttle body. Retarted timing will make it backfire and/or stall. Keep us updated!
Old Dec 29, 2008 | 11:42 AM
daroach1's Avatar
ok went through every thing once again on sunday.
Even threw the timming light on, just to find out, the spark I thought I had was insufficient.Dahhhh. So when I leave work today I will be replacing the coil. With my fingers crossed I will then turn the ignition key. And hope.
Will update after the key has been turned.
Old Dec 29, 2008 | 05:08 PM
daroach1's Avatar
So the key was turned and once again I am without a running blazer.
Let me recap what I have done
1 started on the 22nd
2 did not start on the 23rd
3 checked fuel pressure and changed out cap and rotor on the 24th.
4 humbugggg on the 25th
5 replaced module on the 26th
6 rechecked everything I did on the 27th
7 tried to check timming but could not because of insufficent spark on the 28th
8 put on new ignition coil on the 29th.(by the way it tested faulty)
Guy at the part store said it could be the pick-up coil. Have to wait until tomorrow.Getting really cold.
Any one have any other ideas?
Old Dec 29, 2008 | 05:57 PM
Blazin_Jason's Avatar
My jimmy just stopped firing all together on me once. I just ended up replacing the whole distributor as it was only slightly more than a new ICM. The pickup coil could be your problem.
Old Dec 29, 2008 | 10:56 PM
Pickup coil/stator coil could cause that....
Old Dec 29, 2008 | 11:06 PM
daroach1's Avatar
OK
I took the distributor out . And I am ripping it apart to replace the pick-up coil. Everything is going fine . I checked the old one and its bad so I replaced it. T^he old pick up was completely fried and totally melted.So,Got the new one in, everything is starting to look good again. When I completely rebuilt the dist. I went to spin it and feel it out. Felt rough so I take a closer look. Son of a mother trucking itch. The magnets inside split where the factory rivits hold it in.
Looks like the magnet failed causing both coils to fail.
Anyone know if that mag is replaceable or am I going to the bone yard?
Oh yea. Still sitting like a rock outside far away from its garage. Its a sad blazer.
Old Dec 29, 2008 | 11:49 PM
daroach1's Avatar
Going to the bone yard in the morning. Selling distrbutors for 50 bucks. Half of what they are new.
Is this a bad idea. I can rebuild with all the new parts I already have.
Or, should I just get the new. Warrantty and all.
Open to opinions
Old Dec 30, 2008 | 01:18 AM
mr.vls's Avatar
When my distributer went bad I found out that NAPA sells a complete rebuilt distributer. I remember it being just a little over $100.00 plus the core return.
Old Dec 30, 2008 | 01:20 AM
I would get a new one, before you started replacing the ICM, pickup coil etc :P
