No fuel coming out of injectors?
Old Jul 12, 2009 | 11:28 AM
tcrocker's Avatar
tcrocker is on a distinguished road
Question No fuel coming out of injectors?
I have a 91 S10 blaser 2wd. The elec fuel pump was not working so I replaced the pump, fuel pump relay, and even the distributor. And it still wont run. The fuel pump wont even come on. I jumped the relay and the fuel pump runs but still no fuel to the injectors, I pulled the fuel line off the and it's getting fuel. I'm at a loss need help.
Old Jul 12, 2009 | 05:08 PM
If your pump is not coming on when it should, it sounds like it could be a problem with the ignition switch or with the ECU itself. If either of these were not energizing the proper circuits, it would make sense that the injectors and pump would not receive power. You can test the injector wiring for power with a noid light.
Old Jul 12, 2009 | 06:00 PM
tcrocker's Avatar
I went out to check if the injectors were getting power and they are not. Is it the ecu then? THe day it died the rpms maxed out and the motor was was running at normal rpms.
Old Jul 13, 2009 | 05:54 PM
tcrocker's Avatar
Put the multi meter on the injector wireing and it's getting 1.2 volts. The blazer will run if I spray starter fluid in the intake. I know this is not good on the engine but I just wonted to see if the engine would run.
Old Jul 14, 2009 | 09:01 PM
tcrocker's Avatar
You are going to love this. I rechecked the fuses to day with a multi meter and found a bad one it looked fine in the light but the meter doesn't lie replaced it and it fired up. Boy do i feel like a fool.
Old Jul 14, 2009 | 10:45 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
happens to the best of us. lucky you caught it before you took it to a mechanic.
blazen_red_4x4
Apr 19, 2015 02:44 PM
Gusman
Jan 19, 2013 09:06 AM
dice631
Aug 21, 2008 10:07 PM
matt_87_s10_blazer
Jan 26, 2006 09:02 PM
mytruck2
Oct 10, 2005 12:45 AM
