no lights!
Old Sep 30, 2005 | 06:00 PM
ccvair's Avatar
ccvair is an unknown quantity at this point
Default no lights!
hi im working on a 85 f/s blazer and I have no headlights or tail lights! the dash lights aint working either! I have turn signals and thats it. what do I need to be looking at? is there a fuse or is it on a fuseable liknk? help!
Old Sep 30, 2005 | 06:19 PM
Default RE: no lights!
Definitely sounds like a fuse problem. I am not too sure where your fuse box is, but it'll mostlikely be under the dash and probably uses the glass tube type fuses. I also don't know if your blazer will have a fuse block cover, but if it does, take a look at the diagram on the cover to get an idea of what fuses cover the headlights and parking/tail lights. I am pretty sure that there will be more than one fuse that would control these functions.
If/When you find the fuses and replace ones that are blown... If they blow again, then you have a short somewhere in the wiring. If that's the case, then I would suggest you head to Sears or equivalent and pick up a cheap fault finder. It should make the job of finding the short much easier.
Old Oct 2, 2005 | 11:44 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
I'm having similar problems. I have an '87 S10 Blazer and don't have taillights, brake lights, hazard lights, or dash lights. I've found that the brake lights and hazards share a fuse, and the taillights and dash lights share a fuse. If I change the fuses, I can get about a minute down the road before they blow again, so I'm pretty sure that I have a short somewhere.
I picked up a test light and a multimeter at work and have been working on finding the short.
I would take a look at the fuses, but it's also possible you have a bad headlight switch.
Old Oct 3, 2005 | 02:05 PM
Hanr3's Avatar
Make sure all your lights are grounded.
Have you tried a new light switch yet?
edavison
Dec 20, 2010 09:55 PM
cjs030901
Jun 7, 2007 08:51 AM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
rryker
Apr 25, 2006 04:14 PM
