Ocassional Check Eng light Flashing
Old Mar 29, 2007 | 09:39 AM
arbowman's Avatar
arbowman is an unknown quantity at this point
Default Ocassional Check Eng light Flashing
When pulling hills or sometimes times early in the morning, my '95 S10 Blazer Eng Code W with CPI check engine light comes on and flashes then goes away. Not sure what this might be, it differenly seems to have a miss when the light is flashing, just wondering if the light is not staying on is it really throwing a code.
Any help always appreciated. thanks
Old Mar 29, 2007 | 10:48 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Ocassional Check Eng light Flashing
A FLASHING check engine light means the PCM is detecting a Catalyst DAMAGING missfire. You have a bad miss my friend....if it only happens under load.....check or replace your plugs and wires first.
Old Mar 29, 2007 | 11:08 AM
arbowman's Avatar
Thank you very much, I'll get dirty Sat. morning then.
It diffently feels like a miss. The plug on the driver side closest to the fire wall is a pain in the rump roast for sure.
Old Mar 29, 2007 | 02:40 PM
lastcoupe's Avatar
Nah it's the one in the middle of the driver's side (#3).
Old Mar 29, 2007 | 11:46 PM
Blasir's Avatar
Banned
Blasir is an unknown quantity at this point
One of your plugs may be loose. Does it only do it in the morning when it is not at full operating temp? Then the light stops flashing and the SES light goes out? When the engine gets hot the heads expand and your loose plug isn't loose anymore. I had to tighten my drivers side rear plug the other morning. I could hear it though when I listened inside the drivers wheel well. Mine did the same as yours for 2 mornings in a row. I'm going to check them all this weekend.
kerrhbk
14
Jan 17, 2012 03:53 PM
toydoc
Apr 28, 2011 08:16 PM
zombiewoof
Feb 1, 2009 12:06 PM
downja
Aug 19, 2008 08:32 PM
arbowman
14
Jul 9, 2007 07:11 AM
