odd whirling sound
Old Jul 30, 2008 | 09:26 PM
rebelchevy's Avatar
rebelchevy is an unknown quantity at this point
Default odd whirling sound
when i crank my 89 s10 blazer up it makes a whirling sound i replaced the belt and added some powersteering fluid but its still there it only started it monday morning and it won't quit i can't tell if its coming from the water pump or powersteering pump or alternator i tried turning the wheel but its still there anybody have any hints
Old Aug 6, 2008 | 06:36 PM
rebelchevy's Avatar
Default RE: odd whirling sound
ok i replace the tension pulley and the belt but its still there i am think iys the water pump cause its starting to try to over heat
Old Aug 9, 2008 | 07:34 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
sounds like the bearing in the Water pump is bad because you mention it starting to overheat
Old Aug 10, 2008 | 11:22 PM
rebelchevy's Avatar
ok just replaced the pump and fan clutch and still have the whirling so i swapped the alternator so of it went away so i think its my alternators but it might be the ac idk the powersteering pump pulley has a crack but its been that way since i bought it a few months ago and i changed the3 belt after it started making the soundi have a new pulley i am puttin on it at work tomorrow and a new thermostat cause its still over heating with a new pump.the idler pulley and tensioner pulley both had wornout bearings so i replaced these to theres not much it can be now
Ryan98Jimmy
Jul 29, 2012 02:38 AM
TAS
Apr 3, 2012 12:51 PM
Phil
Apr 5, 2010 10:20 PM
joe_zish
Jun 14, 2009 08:59 PM
filtalr
Oct 3, 2007 07:45 PM
