Oh god wth is wrong now
Old Jun 3, 2009 | 12:36 PM
That is one way to see if you are getting fuel, but that does not mean the fuel is at the appropriate pressure...
Since the fuel pressure regulator is inside the throttle body itself, it could be a problem there. You could test the injector harness with a noid light which will light up if the injectors are getting the proper injector pulse.
Old Jun 3, 2009 | 05:05 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Sounds like your Fuel pump its not sending the correct pressure i heard its very common for the 94's
Old Jun 3, 2009 | 05:53 PM
RolingKCBlazer's Avatar
RolingKCBlazer is an unknown quantity at this point
I'll swap it out once the rain stops
Old Jun 8, 2009 | 09:24 PM
Ok took the Fuel pump out of the other running blazer swaped it over into mine and it dont even make the whine noise like its powering on.... could i have wired it wrong? and one got a diagram on how the wires should be?
Old Jun 8, 2009 | 09:35 PM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
is it grounded properly ?
Old Jun 8, 2009 | 09:38 PM
yeah i re hooked up all 4 wires. never unhooked the ground wire from the frame
Old Jun 10, 2009 | 09:03 AM
mr.vls's Avatar
Have you checked the fuel pump relay, and the fuse for the fuel pump relay.
Old Jun 10, 2009 | 04:56 PM
yeah relays are good and working.
Old Jun 11, 2009 | 05:19 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Do you mean you replaced JUST the pump, swapping it from one hanger assembly to yours, or did you swap the whole hanger assembly?
If you swapped the whole hanger assembly, you'd have to unbolt the ground strap from the frame...
I'd suggest doing that anyway, just to clean up the ring end and the spot on the frame it sits on, to make sure you're getting a good ground.
Old Jun 11, 2009 | 05:56 PM
where on the frame dose it connect? think u could get me a picture? i took the fuel pump out of my other blazers gas tank an put it in this one.
