oil leak dipstick cracked?
Old Apr 22, 2010 | 11:38 PM
fruggy's Avatar
fruggy is on a distinguished road
Default oil leak dipstick cracked?
Hello I have recently developed a problem. truck is a 94 s-10 blazer 4. vortec. has 160k. never leaked a drop of oil until recently I was driving and smelt something burning. looked under the hood and saw oil spray on the passenger side of engine. It is wet underneath all on the passenger side and trails to the bottom of the oil pan near the drain plug. I think its the dipstick? Its not coming from valve cover. Its not wet on top at all. I can only think of it being the dipstick. It seems like it sprays its wet on the frame of the passenger side of motor and some sprays on the middle part of the exhaust manifold. even gets on the middle spark plug wire I can see it smoke.Also looked through the wheel and lifted the rubber guard and was all wet right near where the dipstick goes in and all on that side.I dont think it would be oil pan gasket cause it seems to spray. It just makes sense it would be the dipstick.any other ideas? thank you. oh and if you think it is the dipstick how hard is it to change? thanks in advance.
Old Apr 24, 2010 | 02:59 PM
fruggy's Avatar
bump...please help
Old Apr 24, 2010 | 05:44 PM
abig84's Avatar
Doesn't sound like it would be the dipstick. Just like the oilpan its not under presure. Is the oil sending unit on that side or any other hoses/ sensors?
Old Apr 24, 2010 | 06:10 PM
fruggy's Avatar
Not that I know of. The oil sending unit is more in the middle and the lines go to the other side of the motor (not where its leaking from).and the oil sending unit looked clean when I checked. Its hard to tell cause it doesnt leak when its just idling, i have gotten under and checked and dont see anything. I cleaned all the oil off too and tried watching but it only does it when driving.so idk... thanks for the reply. any more ideas?
Old Apr 25, 2010 | 02:41 PM
Is the PCV system (and vent) working properly? If it isn't, you could get oil pushing past the dip stick tube in the block.
Old Apr 25, 2010 | 08:15 PM
fruggy's Avatar
well actually the valve cover without the oridinal pcv valve the one that had just a hose going out if it broke, so I just put another pcv valve on it. Would that have anything to do with it? I believe both pcv valves are good they both shake. I was told thats how you tell. thanks
Old Apr 25, 2010 | 08:19 PM
So you do not have a fresh air make up attached to the system (the hose that runs from the intake duct on top of the throttle body to the valve cover)?
Old Apr 25, 2010 | 08:34 PM
fruggy's Avatar
no I have that. I meant the other side of my valve cover just has another pcv valve as well. I see on my other valve cover my pcv valve has a hose that runs into my intake under the top cover that says vortec on it. I always had that setup, but on the other side I just had a hose that was maybe 8 inces long and went no where. when I was changing my spark plugs it broke off along with the gromment, so I bought a new grommet and just put another pcv valve on it.
Old Apr 26, 2010 | 06:06 AM
Maybe a picture of what you have is in order.
Old Apr 26, 2010 | 12:09 PM
fruggy's Avatar
ok will do. All I have is my camera on my phone but its a pretty good one. Ill try and show where its wet from the oil leak as well
