Oil pressure gauge question
Old Jul 1, 2020 | 02:36 PM
Juggalonmd's Avatar
Juggalonmd is on a distinguished road
Default Oil pressure gauge question
Hey guys. 89 s10 blazer 4.3 2wd. I've been noticing that oil pressure gauge needle is real jumpy and moves alot, mostly when I'm driving and after it's warmed up. Is this a normal thing or should I be concerned? I've had other chevys that have done the same thing but never had a real problem
Old Jul 1, 2020 | 04:58 PM
2001ZR2's Avatar
Not sure what you mean but the oil pressure should move with RPM.
You should have at least an indicated 10 psi at idle but the sounds the engine makes is more important. I have a Z28 that shows 0 at idle on warm days but is quiet. Think its a wiring or gauge problem as I have changed the sending unit
Old Jul 3, 2020 | 10:01 AM
The sender units can go bad but also as said above, you could have some loose wiring.
Old Jul 10, 2020 | 11:44 AM
Sandy chain's Avatar
Sandy chain is on a distinguished road
If you want to know your oil pressure, you need to install a gauge.
In 1990 I bought a new 1991 s10 pickup. The oil pressure gauge was all over the range, mostly pegged at the top.
I took it in for warranty repair 2 times, and they never got it right. My current 1991 S10 gauge bounces around sometimes so fast I can hardly see the needle.
SimonV
May 15, 2014 12:29 PM
Dustin Grant
15
Apr 9, 2014 07:26 AM
sprbld417
Jan 27, 2011 12:08 PM
westleybidlock
May 24, 2009 02:27 PM
vin791
Nov 18, 2008 05:26 AM
