oil pressure problem
Old Jun 4, 2008 | 05:23 PM
warware's Avatar
warware is an unknown quantity at this point
Default RE: oil pressure problem
so the sending unit is inside the drivers side valve cover? also i have no idea where to find the iat sensor. can you guys show me some pics to help me out?
Old Jun 4, 2008 | 07:43 PM
No. I guess I have to get more generic... It is at the back of the engine, between the distributor and the back of the driver side valve cover....
Old Aug 18, 2008 | 06:26 PM
SBreisch's Avatar
SBreisch is an unknown quantity at this point
Just found this website trying to figure out the same problem. About a month ago, son called me said engine was smoking and no oil on dipstick. I checked, no leaks, drained 5 quarts out. Put 5 new quarts in and it showed on the dipstick. Same thing happened this weekend-no oil pressure and I drained out 5 quarts. Now I have a rod knocking. Mechanic says spider injector is leaking gas into crankcase which is thinning the oil too much. He can't explain the no oil on the dipstick issue. Help!!!!
Old Aug 18, 2008 | 08:44 PM
Test your fuel pressure first before condemning the CPI unit or FPR. Specifically, pressurize the system, then turn the key off and monitor the pressure. If it drops quickly, the FPR is blown.
A rod knock is not going to get any better.
Kaser1026
Dec 30, 2012 05:58 PM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
