Parking brake cable and routing
Old 11-20-2022, 06:51 PM
mr.vls's Avatar
mr.vls will become famous soon enough
It appears that you have the same brackets underneath as my 2WD, I would think the routing is the same.as the 2WD. The driver's side goes through the bracket underneath and through the frame to the outside of the frame rail through the mounting tab and routed to the rear wheel. I installed a rubber gromet on the outside mounting tab to secure the brake cable better.
Old 11-20-2022, 06:56 PM
GreyFox1911a1's Avatar
GreyFox1911a1 is on a distinguished road
Alright then, I will order the cables and attempt to route mine according to yours, thank you so much for your help, I will post an update after I get it done. Thanks again and have a good night,
Old 11-24-2022, 05:33 PM
Default Got it done
Thanks mr vls, your help is much appreciated, just got done according to what you showed me , got it adjusted and working properly, thanks bless you and happy thanksgiving!
Old 11-25-2022, 08:06 AM
mr.vls's Avatar
Glad I could help. My rear brakes have been converted to disc using parts from a 2000 Blazer. The connection at the brakes is different than the drum brakes. I had ordered replacement brake/cable housings from Bruin brake cables. I replaced the cable inside the housing with cables pulled from a 2000 blazer and cut them to the correct length and crimped on new cable stops.
Cable stop crimped on to rear brake cables.
Rear brake cable attached to rear disc.
Rear brake cable attached to connector
TireGrit
02-15-2017 10:20 AM
TexasRider
05-30-2013 09:10 AM
Black99blazer
03-05-2012 12:32 PM
DaveRush
11-09-2011 12:07 PM
WolfPack
04-09-2008 12:18 AM
Quick Reply: Parking brake cable and routing
