pitman arm on a 94 4x4 blazer
Old Jun 4, 2010 | 09:34 AM
ethan.zick's Avatar
ethan.zick is on a distinguished road
Default pitman arm on a 94 4x4 blazer
i need to change my pitman arm any tricks to it?
it apears i neeed to un bolt the steering box because the pitman arm is like 3/4" from the crossmember i cant even fit a wrench to take it off
Old Jun 5, 2010 | 07:43 AM
ohsofly's Avatar
Remove the steering box, there is 3 or 4 large bolts that hold it to the framerail and disconnect the input shaft. You will probably need a pitman arm puller to get it off the steering box splines. Mark where everything was aligned before you take anything apart.
Old Jun 10, 2010 | 12:55 AM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
Do what ohsofly said above. I did mine on my 84 and it was a little tricky. I used a 33mm socket and breaker bar to get the nut that holds the pitman arm to the steering box and then just put the pitman arm puller on there.
Old Jul 29, 2010 | 09:57 PM
michaelross's Avatar
Banned
michaelross is on a distinguished road
I have bought a pitman arm puller online and it really is a great tool. I used to have much difficulty changing the pitman arm but not anymore..
Old Jul 30, 2010 | 07:12 PM
rusty91's Avatar
rusty91 is an unknown quantity at this point
it is like everybody says when your done make sure the idler and pitman arm are the same length from the frame to keep your alignment correct
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
