play in steering
I did body work on my truck where it sat in the shop for 3 months and I drove it home and the ignition cylinder gave out on my so I replaced it the other day but now I have a lot of play in the steering wheel about 2" on the left and 4" on the right. I was wondering is there anything I could have taken apart when replacing the ignition cylinder that might have not got put back together right that would cause that much play or is it something else?
well I haven't had time to check any of that yet but I would assume all my steering and suspension parts should still be good as I just replaced all of it last year because a lot of it was going bad I replaced it all with Moog parts. I was just assuming it might be something to do with the steering wheel not being put back together correctly.
NOTE: The factory bushing setup has rivots (4) holding the bushing in place. You'll have to grind those off to replace the bushing, and use hardware to put it back together.
![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
Kojak
01-23-2008 06:28 PM
