Please Help
Old Oct 1, 2008 | 04:46 PM
ZEN74V2's Avatar
ZEN74V2 is an unknown quantity at this point
Default Please Help
hello all. i'm new to this forum and couldn't think of a better place to get some help for my 1994 chevy s-10 blazer. it's push button 4x4, if that helps any, 4.3 vortec. my problem is that when i start my truck cold and put it in reverse i have this god-awful rumble-roar from the rear. it also has a noticable roar when i put it in drive. now once the vehicle gets warm, one or two miles of driving, reverse and drive are fine andthe rumble-roar is gone. being as though i am not a car person i was wondering if anyone had any idea what this is. i don't want to be taken by a repair shop. thanks in advance
Old Oct 1, 2008 | 04:53 PM
Default RE: Please Help
I am a bit time constrained at the moment and can only move this to the appropriate section so that you can get the help you need. I will reply back later when I can if someone else does not help out first.
*Moving to 1st Gen Tech*
Old Oct 1, 2008 | 05:04 PM
ZEN74V2's Avatar
thanks swartlkk
Old Oct 1, 2008 | 07:22 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I've seen them(94's) that when cold, mostly in reverse, the fan touches the fan shroud. Visually look at it -it should leave some evidence in it is indeed this. Just an initial wild guess based on the description you gave and a sound I didn't hear. JP[&o]
Old Oct 2, 2008 | 09:48 AM
ZEN74V2's Avatar
you are exactly right. that is what the sound is (the fan shroud) when i firststart the vehicle. i've checked that before but in addition there is also like a whine of the trans too. but nevertheless the sound in reverse is definately a different noise. i'm thinking that i need to change the fluid in the transfer case, but you tell me.
thanks
Old Oct 2, 2008 | 12:36 PM
if noise in reverse(again I from here can't hear it!) drop the driveshaft(main one) and check the rearmost universal joint. Maybe we'll get lucky with that guess. I doubt the transfer case is the source on any noise especially if your not in four wheel drive as on a 94 that system is disabled in 2wd. Servicing the tranny-depending on mileage last done, may not be a bad idea-there are also additives that I'm sure the experts out here will chime in on for possibly lessening your noise(if indeed that is in the tranny). BTW-if there is a bad u joint replace it then test drive as it may be the source of all your Blazer issues! JP
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
