power but no power
Old Jan 17, 2007 | 07:42 PM
nate2003456's Avatar
nate2003456 is an unknown quantity at this point
Default power but no power
to start of my blazer is 94 s 10 and i just tore it apart down to my heads for gaskets and after i put it all back together and go to start it there was nothing. I have been looking for disconected wire and un hooked grounds but have not seen any thing. and yes the battery has power.
Old Jan 17, 2007 | 11:28 PM
Default RE: power but no power
dose any one have any ideas on what it could be
Old Jan 17, 2007 | 11:36 PM
20Blazer00's Avatar
ORIGINAL: nate2003456
Distibutor out of time?????or a sensor ie cam position/crankshaft position etc...
Old Jan 17, 2007 | 11:44 PM
hillbillyinOhio's Avatar
are you getting anything at all?? check your connections at the battery.
there is no powere even for the cars lights.
thats why i thought about the ground.
is it possible that there might be a ground in the wrong spot.
Old Jan 17, 2007 | 11:48 PM
there is power at the conections
Old Jan 17, 2007 | 11:53 PM
make sure that you have power at the alt. check the wires to make sure that you are getting voltage. starter hooked up??
Old Jan 18, 2007 | 12:00 AM
dose those conection have any thing to do with powering the rest of the car
Old Jan 18, 2007 | 12:12 AM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Could it be any fuses? You may have short circuited something while dissembling or resembling the top end of the engine.
Old Jan 18, 2007 | 12:15 AM
i would check the connectuions on the battery, and go from there,
