problems with new blazer
Old Feb 1, 2012 | 01:12 PM
Maestro's Avatar
Maestro is on a distinguished road
Default problems with new blazer
after a long haiatis i have to check back in to ask what the heck is wrong with my new blazer
problem: will crank, but will not run for any amount of time unless i saw on the throttle to keep it running...
my guess is the TPS,....no vac leaks that we could see or hear
**EDIT**
new blazer is a 1991 with the 4.3 TBI 4x4 if that helps...
Old Feb 2, 2012 | 10:51 AM
Maestro's Avatar
can anyone here help at all?.....
Old Feb 2, 2012 | 11:33 PM
xgiovannix12's Avatar
Id start with a fuel pressure diagnosis
Have you tested the fuel pressure by the fuel filter ?
the pressure should be no lower then 9 psi when the key is turned to on position
a bad tps would trigger a code do you have your ses light on?
Old Feb 3, 2012 | 12:31 PM
Maestro's Avatar
where is the FP test port located?.....or will i have to make one?
and no...theres no service lights on...
fun fact....the fuel gage is stuck on over full
Old Feb 3, 2012 | 01:13 PM
mr.vls's Avatar
1st gen TBI blazers do not have a fuel pressure test port. I have a TBI fuel pressure test kit the I purchased that I would splice into the fuel line. I would tie in at the front frame where the fuel lines go through the front crossmember. Autozone might have a kit as part of their loan a tool program.
Old Feb 3, 2012 | 03:33 PM
yup what he said ^^ i just got home =P
Old Feb 4, 2012 | 01:21 AM
ohsofly's Avatar
Ditto. And the gauge for your fuel spikes to full when the ground is rotted off. So have a look on top of your gastank for the loose wire and reground that beeoch so you can see how much juice you got.
Old Feb 8, 2012 | 05:51 PM
Maestro's Avatar
finally got 'er running again....just had to replace this little seemingly insignificant connecting hose ....now she runs fine...
Old Feb 8, 2012 | 06:11 PM
the pics sorta small what is it ?
Old Feb 9, 2012 | 11:33 AM
Maestro's Avatar
its the very short connecting hose thats on the in-tank assembly. the one i replaced was desolving...
the circled part in the pic
Attached Thumbnails problems with new blazer-electric-fuel-pump-assembly-module-multipoint.jpg
Chevyman61
Jan 21, 2015 10:53 PM
Northernguy
Oct 21, 2012 03:48 PM
bigkeith11
Sep 19, 2012 01:12 AM
2000jimmbo4x4
Aug 23, 2010 07:10 AM
upblazer95
Apr 4, 2009 08:27 PM
