problems with oil pressure gauge
Old Feb 3, 2008 | 12:27 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default problems with oil pressure gauge
recently i have had problems with my oil gauge it jumps down to zero and the check gauges light comes on when ever i come to an complete stop. but there is plenty of oil in it. itdoes not leak oil any wherecan any body help
Old Feb 3, 2008 | 01:22 PM
rriddle3's Avatar
Default RE: problems with oil pressure gauge
Sounds like either a bad sending unit or oil pump. When the engine is idling, does the gauge just stay at zero, or does it show increasing pressure? When the truck is cruising, what does the gauge show? If it's a bad pump, this is not something to ignore.
Old Feb 3, 2008 | 02:36 PM
at idle it sits at about little under 40 at cruising speeds in between 40 and 50 it never sits at zero when im like sitting at a long red light of some sort
Old Feb 3, 2008 | 02:44 PM
rriddle3's Avatar
You haven't said what year your Blazer is, but I'm assuming it's a 1st gen from the catagory of the post. From the info, I would suspect a bad sending unit. Have a manual pressure check done on the oil pressure and see what that says. The pressures you posted look to be well within specs. You're not experiencing any unusual engine sounds are you, like a tapping from the valve train, or deep knocking sound?
Old Feb 3, 2008 | 02:50 PM
no not at the time
Old Feb 4, 2008 | 04:32 AM
thegr81's Avatar
It does sound like a bad sending unit, just to make sure I would test the oil pressure with a pressure gauge at were the sending unit is located!!
Old Feb 4, 2008 | 01:05 PM
where is it located at
Old Feb 4, 2008 | 02:28 PM
rriddle3's Avatar
Before we go further, tell us what type of Blazer we're dealing with. Putting your vehicle info into your signature will make it available anytime help is needed.
Old Feb 5, 2008 | 10:18 AM
its a 91 4dr blazer with an 4.3 engine
Old Feb 5, 2008 | 10:48 AM
rriddle3's Avatar
ORIGINAL: strong blazer
The unit should be on the top of the engine at the rear, butif it's like the 2nd gen's, the distributor blocks it, necessitating its removal first.If this is the case, get a Hayne's or Chilton's manual to see how to r&r the distributor.
