R/R Oil Pan Gasket without removing Engine
Old Jan 11, 2019 | 09:29 PM
mr.vls's Avatar
Default R/R Oil Pan Gasket without removing Engine
I managed to replace the oil pan gasket without removing the engine. But it was a real PIA. Steps: Drain Oil and remove oil filter, Jacked up vehicle for clearance to work under the car, Removed Y- Pipe from exhaust manifolds, Removed flywheel cover. Removed engine mount bolts, Removed Transmission Mount Bolts, Raised engine with engine hoist, Removed Oil Pan Bolts, Dropped Oil Pan, Spent about an 1 to 2 hours on my back trying to fish the oil pan gasket under the pick up tube and to the other side, I than spent about 3 hours getting all of the oil pan bolts in and the new gasket to properly line up to the oil pan.
mr.vls
Jan 8, 2019 05:58 PM
mr.vls
Jun 29, 2018 03:07 PM
Johnson
Nov 16, 2017 04:58 PM
snobrd
Jun 24, 2011 10:28 PM
bobditts
Jun 18, 2009 06:38 AM
