ready to give up
Old Feb 23, 2008 | 11:13 AM
joshua2427's Avatar
joshua2427 is an unknown quantity at this point
Default ready to give up
hi everyone great site I have a 94 s10 blazer cpi which I am having a heck of a time with lately when I start it up itruns and starts fine at idlebut when I hit the gas at about 2900rpm it starts to run horrible it wont exceed 3300rpm the fuel pressure at idle is 55psi on the throttle its 60-62psi I have new plugs,cap,rotor,coil,fuel filter,plenum gasket,and c.p.i.unit installed already when it starts missing (badly) the fuel psi is still good about 60psi it just dies off like theres a rev limiter on it or something I have checked and done everything imagineable any suggestions would be greatly appreciated I dont want to have to retire my blazer with only 60,000 on the new motor 225,000 on the truckI've had it for to long and love it please someone help
Old Feb 23, 2008 | 11:20 AM
Default RE: ready to give up
Classic symptoms of a failed catalytic converter.
Old Feb 23, 2008 | 12:42 PM
joshua2427's Avatar
I think there isa good chance your right. I got under the truck after I started it and could here the catalytic converterrattling. I grabbed all the shrouds and held them tight to make sure it was the cat. It is coming from inside the cat. I will let you know how it turns out thanks a buch.
Old Feb 23, 2008 | 01:34 PM
x33camaro's Avatar
x33camaro is an unknown quantity at this point
try pulling the O2 sensor out and see if it runs smoother. If it does then you are probably looking at the Cat.
Old Feb 23, 2008 | 01:37 PM
joshua2427's Avatar
After 1 year of troubleshooting it runs like a top again thanks a lot. Perfect diagnosis
ptcoins
Dec 21, 2007 12:16 PM
blznlowxtreme
Oct 27, 2007 02:21 PM
kaercher4
Oct 13, 2007 06:53 AM
deadpool
Sep 14, 2006 06:15 AM
knightrain420
Suspension Tech
Nov 17, 2005 12:14 AM
