rear main seal
It would help if we had alittle information on your truck... I have asked you before and I'll ask again, please put your vehicle information in your signature and attach it to all of your posts. I think I can answer without knowing fully what you have, but please put that information where we all can see it.
If you have a removable torque converter dust cover, then remove it and look up between the block and the flex plate. If you have the 2 piece transmission case, then you have to remove the two plugs in the bottom of the bellhousing area (rubber plugs that are stuck up in there pretty good) and look up between the block and the flex plate. If the flex plate is covered with oil, then you have a rear main seal leak. If it isn't, then it is possible that the oil pan gasket isn't sealing properly. Check your oil pan bolts for proper torque.
Any more information pertaining to that??? What have you tried? You remove the bolts and you pull it down... If you have the bars that run from the side of the engine block to the transmission, you may have to remove one or both of them as well.
ebristol
Apr 1, 2008 04:53 PM
