Recent Gas Mileage
Old Mar 23, 2013 | 07:09 AM
mr.vls's Avatar
Default Recent Gas Mileage
I recently replaced my fuel pump assembly with an Delphi unit. In the process of monitoring the accuracy of the fuel gauge I decided to check my MPG for a few tank fulls. My first check I got 19 MPG and I filled up yesterday and the result was that I got 20 MPG. This is in my 89 GMC Jimmy 2WD, Auto, K&N Air Filter, Injector Pod Spacer, Stock Exhaust with a high flow CAT, and Michelin tires. Most of my driving is highway and I use my cruise control as much as possible.
Old Mar 23, 2013 | 07:19 AM
newguy's Avatar
wish I got 20 mpg
Old Mar 23, 2013 | 07:33 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
the uses synthetic oils in the rear diff may net you a little extra, also better cool, wires and plugs, cap and rotor, last but not least don't forget to check the vacuum lines for dry rot the more efficient it runs the better gas mileage can be all the little things tend to add up over time, good luck on increasing your fuel mileage
Old Mar 24, 2013 | 12:11 AM
clicheche's Avatar
clicheche is on a distinguished road
i just figured mine out. 1994 cpi. 4.3 litre
415000km on the engine.
getting over 18mpg all around. highway i bet it's nearly 25mpg.
have a few things yet to do.
cap and wires surely. haven't even used sea foam yet. ha! that'll be a decent help
kiwiblazer
Dec 2, 2008 10:56 PM
butters
Nov 11, 2008 09:43 PM
lastcoupe
Aug 28, 2006 12:59 AM
Canadian88
Jun 18, 2006 01:51 PM
zero psi
Feb 16, 2005 11:14 PM
