remote oil filter elimiation
Old May 16, 2008 | 06:03 PM
etek ego's Avatar
etek ego is an unknown quantity at this point
Default remote oil filter elimiation
is it possible to remove the remote oil filter from a 4.3l application and put a oil filter adapter on the block instead? what do i need to do this? my vehicle does not have an oil cooler either
Old May 16, 2008 | 06:49 PM
Swain's Avatar
Swain is an unknown quantity at this point
Default RE: remote oil filter elimiation
I believe it is for a 2wd if you use a short oil filter but on the 4wd's there isn't enough room. Someone else can verify that but I'm pretty sure it's what I found when I was looking into the same thing.
EDIT: Just realized this was in 1st gen tech I'm not sure if the answer will be the same. Some food for thought though
Old May 16, 2008 | 07:13 PM
SilverTalon's Avatar
SilverTalon is an unknown quantity at this point
The main reason for the relocation of the filter is to make the job of replacing it easier and to allow for a longer filter, in turn increasing the oil flow.
Is there any specific reason you want to remove the relocator? If not, just leave it where it is. The tubing to and from the filter will help cool the oil a little, and it will be a lot easier to change the filter when it's needed.
Old May 17, 2008 | 10:05 PM
etek ego's Avatar
the 4.3l is sitting in a jeep wrangler frame and i have all sorts of space below but no space above. i found a piece today to get the job done but it will cost me 94 dollars.
racsan
Feb 5, 2011 09:45 AM
nineteensixtycaddy
Mar 28, 2010 02:29 PM
rllamarca
Apr 22, 2009 11:23 AM
doodad69
Dec 1, 2008 01:44 PM
