removing front driveshaft?
Old Nov 26, 2012 | 08:09 AM
swervinblazer88's Avatar
swervinblazer88 is on a distinguished road
Question removing front driveshaft?
i went outside to remove the driveshaft to the front axle on my blazer but it kept turning, i was wanting to know how to stop it from spinning so i can remove the 7/16 bolts?
Old Nov 26, 2012 | 08:53 AM
chris015's Avatar
Shove a long screwdriver between the ujoint and the flange so it puts it in a bind when you turn the bolts.
Old Nov 28, 2012 | 09:36 AM
thx i pulled it off in less than 15 minutes.
Old Nov 28, 2012 | 10:00 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Wait till you go to put it back on LOL.
I still havent got mine back on,lining up the splines and fightingthe snap ring at the male end will be tough to get the female side back over.
Good luck.
Old Nov 28, 2012 | 11:46 AM
Diaita's Avatar
it should go on pretty easy 1sttimejimmyowner, if not, make sure the spring clip isnt damaged.
Old Nov 29, 2012 | 10:10 AM
Well thats going to be difficult to do right now.Im in the process of moving it.
Old Nov 29, 2012 | 10:22 AM
rockp2's Avatar
Could someone elaborate or post a picture on the "spring clip" you are referring to? I just put my '98 Blazer back together and when I put the front drive shaft back in it was easy-peasy. There was no type of "spring-clip". Note: Some PO did work on the driveline and did a crappy job, so along with other missing parts, the spring-clip may be another one.
Old Nov 29, 2012 | 11:33 AM
Diaita's Avatar
right near the tip of the front output shaft on the transfer case there is a spring clip that sits in a groove
Old Nov 29, 2012 | 11:42 AM
rockp2's Avatar
Is it possible for the spring clip to stay in the groove when you remove the driveshaft and I just didn't notice it? Can you tell me what the purpose of the clip is?
Old Nov 29, 2012 | 12:05 PM
rockp2's Avatar
Looked on Alldata, and if I looking at the assembly instructions correctly, I can see the spring clip and groove clearly on a NVG136-NPR transfer case. But it appears (looking at the assembly instructions and diagrams) my transfer case, NVG233 doesn't have this spring clip. Does that sound right Diaita? I'd sure like to know what the purpose of the clip is anyway though, if you would be so kind as to enlighten me. I.E. if it's reataining something...what could it possible be retaining? Thanks much!
