replaced fuel pressure regulator now wont start
Old Feb 13, 2011 | 08:04 PM
wallace's Avatar
wallace is on a distinguished road
Angry replaced fuel pressure regulator now wont start
i just installed a new fuel pressure regulator and cleaned all the fouled plugs now vehicle wont start, i have injector signal and spark and adequit fuel pressure......... im stuck frusterated and out of ideasand need help???????
Old Feb 13, 2011 | 08:25 PM
ffox's Avatar
ffox is on a distinguished road
Did you bleed all the air out of the injector system? Just turn your key 4 or 5 or 6 times and let the fuel pump run, should eventually push all the air out..
Old Feb 13, 2011 | 08:51 PM
wallace's Avatar
ya i have fuel in the regulator and in the cylanders im thinking it might be a bad regulator or it didnt seal properly and is fludding out the regulatoril find out tomarrow if you can think of anything else please let me know??
Old Feb 14, 2011 | 06:57 AM
ffox's Avatar
How much fuel pressure do you have? You should have at least 60 to 65 for it to start right, especially when it's cold..If you still have the intake off, take one of the injectors and stick it in a bottle, now crank the engine and see if gas sprays out..It shouldn't just dribble or drip, it should be a cone shape spray.
If the engine is flooded, hold the gas pedal all the way on the floor and crank the engine a few times, the computer will go into the flood mode and clear it..
Old Feb 14, 2011 | 07:06 AM
While you are using the fuel pressure gauge, monitor the fuel pressure leak down rate. If it pulls down more than 5psi in the first few minutes after the pump shuts off, you have a leak.
Old Feb 14, 2011 | 09:46 AM
mr.vls's Avatar
Is this a CPI or TBI engine? I am guessing it is a CPI.
Old Feb 14, 2011 | 11:13 AM
wallace's Avatar
i have good fuel pressure and no leaks found it holds 62psi for more than ten min but the regulator itself seems to be flooding out like it didnt seal properly, i replaced both o- rings and still not starting ?? i tried holding gas peddle on the floor and cranked and cranked it still nada
Old Feb 14, 2011 | 02:04 PM
ffox's Avatar
I would think if it didn't seal properly you would be losing pressure. All it does is limit the amount of fuel that can return to the tank so it can maintain the proper pressure. The main injector could be plugged. You need to determine if your injectors are spraying properly. solid fuel won't burn, it needs a vapor.
Old Feb 15, 2011 | 09:45 AM
ohsofly's Avatar
You cant flood the regulator. It just maintains constant pressure in the line. If it didnt seal right, you would be leaking down.
I would be looking over all the wire connectors, and closely inspecting that harness on the injector top, its an 8 dollar item and should be changed when you are inside there anyways. Have a real close look up the 2 holes on the injector plug, are those hair thin wires parallell or crooked???? You also have a coolant temp sensor up there that will cause your truck to not start if not plugged in again. Maybe wanna check the connector on the knock sensor too, it could have been knocked off, this is on the back of the engine on passenger side most times.
Are you using a gauge for real? Here is a video that may help you do the test proper.
http://www.youtube.com/watch?v=fdlUzSLRdao
north40s
Oct 19, 2011 05:00 PM
jasonscottclack
May 28, 2011 09:47 AM
yanni011
Jan 7, 2011 08:59 PM
01blazer1981
Jun 26, 2008 10:57 AM
broke33
May 1, 2007 10:45 PM
