Reverse lights no worky
Old Jun 11, 2010 | 07:47 PM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
Default Reverse lights no worky
So I fixed the license plate bulb the other day and now the reverse lights do not come on. I just noticed when I was backing into the driveway last night. Who knows how long they have been out for. Checked all fuses and they are good. Tested the socket and it has a good ground but no voltage going to it. Back up light switch maybe? And where is this switch located and how do I test it?. Is it the 2-pin connector on the side of the transmission? Any ideas? Thanks in advance for the help.
Old Jun 12, 2010 | 09:28 PM
Anything?
Old Jun 13, 2010 | 12:11 AM
ohsofly's Avatar
Mine dont work unless i lift the shift lever up a little when in reverse, I think my cable is a little slack or something. Try wiggling around the shift lever and adjusting the cable.
Old Jun 13, 2010 | 01:22 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Yeah i was going to say the same thing as ohsofly
Old Jun 13, 2010 | 03:08 PM
Its a 5-speed. There is no cable is there?
Old Jun 15, 2010 | 01:17 PM
Well I will try replacing the back up light switch today. Let you know how it goes.
Old Jun 15, 2010 | 07:52 PM
Replaced the switch and the lights still do not come on. Anyone have any other ideas? Or maybe a diagram of the circuit that the reverse lights are on?
Old Jun 17, 2010 | 08:00 PM
Okay well I tested the sockets and the light green wire which is suppose to be the hot wire is getting resistance at both reverse sockets. I tested the two wires going into the turn b/u fuse at the fuse block and the left terminal is getting resistance. So my power wire is going to ground somewhere. Anyone have a good diagram of this circuit? I am not too good with electrical but I am trying to understand it with the help of my dad.
chris015
Feb 27, 2013 07:01 AM
BaLListic_Evo
Jun 4, 2010 03:38 PM
flipzat
Apr 1, 2010 01:58 PM
gmaltese
May 12, 2007 09:55 PM
