Rough Idle and surging idle?
Dunno about your generation but in 2nd filler tube, it's impossible to get a siphon hose to the tank.
Depending on the state of the evap system {or you could disconnect and block vent tube to the canister.} disconnect fuel filter and put large pan under line. Shopvac on 'blow' and wrap rag around hose so outer part of tube is covered. Air pressure in tank will start the siphon.
Worked for me on another car. When I did my Bravadiva the siphon just started by itself.
Yeah can't siphon any of the OBD-II vehicle tanks - too much crap in there for the evaporative emissions system.
And yes - the air hose trick works great. Forgot about that one.
I've dropped a tank with about 10gal of fuel in it. It's possible if you go carefully and support the tank really well. I built a wooden cradle to put on my jack similar to a transmission jack saddle. I was able to lower the tank enough to get the fuel lines disconnected. Once the tank was down I was able to pour the gas out through the filler tube.
Well I attempted to take the bolts out of the support straps today with an impact and could only get 1 out and gave up after 3 hours.
I have decided that I am gonna pull the carpet up and cut an access panel out with a jigsaw in the next few days, wish me luck!
Use heavy duty snips or a nibbler after carefully drilling pilot holes.
- and of course after you drill those holes, crawl under and see if it's practical after all
Lemme guess on that tank bolt.. you get a few turns, it freezes up. Here's the process:
Wire brush
Pblaster.
wait..
Turn till stiff
Back off halfway
wire brush
pblaster
turn till stiff again
back off
brush
pblaster
- repeat as needed
Tedious but always works.
Home shop impacts aint got enough ***. And pro shop impacts break the things as often as not.
