runs then dies
Old Feb 4, 2016 | 12:59 PM
mr t's Avatar
mr t is on a distinguished road
still looking toget her fixed so any ideas anybody? service engine light is on even after leaving the battery off all night! NO fault codes showing?
Old Feb 14, 2016 | 01:10 PM
mr t's Avatar
could it be the fuel pump relay breaking down when warm?
Old Mar 17, 2016 | 02:44 AM
mr t's Avatar
HELP ME PLEASE! UPDATE....so after changing the following parts its still the same, fuel pump/fuel filter/ignition moduel/coil/idel air unit/fuel pump relay and the oil presure sender unit, any help would be most helpful, thanks
Old Mar 23, 2016 | 02:27 AM
Dealing with the same here. 1994 4x4 S10 Blazer 4.3 TBI.
Just got a new distributor (reman) and was swapping that one in. Bugger have to make a long tube with a slit to turn the fuel pump in order to properly drop it in.
What I have come up with is the following:
- I always had spark and fuel injection. This can be normal as during start it runs in closed mode. Fuel means that i have an rpm signal from the ignition module.
- When cold it starts and runs. SES/MIL light is on during cranking (normal) and exinguishes when it runs.
For once I could observe some hesitations in idle and when revving it to 2'000 rpm I got intermittent weird rpm indications. This could be consistent with the no start issue when it becomes steady. Maybe loss of rpm signal.
I've no time to fumble with my ALDL cable and read out the codes. Replacing the distributor maybe today, latest over the easter weekend.
I'll let you know.
Old Mar 30, 2016 | 05:26 PM
Jessy M Fletcher's Avatar
Jessy M Fletcher is on a distinguished road
I'm having a similar issue with my 94 blazer w code.starts when cold but something seems to tell the fuel to shut off. It has the correct fuel pressure even after it dies. It's got me so puzzled. Any help would be awesome
Old Mar 30, 2016 | 07:30 PM
mr.vls's Avatar
The problem could be a fuel mixture issue. When the engine is cold the Fuel Mixture is rich and when the engine warms up the fuel mixture is leaned out. The O2 sensor and the Temp Sensor for the ECM controls the fuel mixture once the engine is warmed up. Faulty readings could from one or both could cause the symptoms your having. The Temp Sensor for the ECM is a 2 wire Sending Unit by the water inlet at the front of the engine.
Old Mar 30, 2016 | 07:41 PM
I replaced my temp sensor today and it didn't do it I will look into the o2 sensor to rule that out.I know it's not very old but that don't mean any thing. Haha thanks for the advise.
Old Apr 4, 2016 | 06:47 PM
Well I chech my fuel pressure again on Saturday it was no where near what it was last time. Wouldn't go past 40 psi so I ordered a acdelco pump should be in soon. Hopefully this fixes the problem.
Old Apr 7, 2016 | 06:01 PM
danathan's Avatar
danathan is on a distinguished road
im having the same exact issue I hope we can figure this out. I too just changed the icm.
Old Apr 8, 2016 | 12:51 PM
mr t's Avatar
ITS ALIVE!!! after doing all the bits listed, i totaly changed the dizzy completley, and its now alive, many thanks for all your help folks
