S-15 rear brakes
Old Nov 13, 2004 | 04:25 AM
rnjohnson's Avatar
rnjohnson is an unknown quantity at this point
Default S-15 rear brakes
I have a 1987 S-15 pickup which has had a problem for quite a while with the rear brakes locking whenever it's cold or cold and damp out. Until the brakes warm up, you can't touch them soft enough to prevent locking. Even the lightest touch and the rears lock dead up. I have to drive down our road with one foot on the gas and the other lightly on the brake to warm them up in the morning. Above 50 degrees and they're perfectly fine. The brakes have been serviced twice since having this problem with new pads and such. Any ideas? Can a proportioning valve have problems only at low temperatures?
Old Nov 13, 2004 | 05:36 AM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: S-15 rear brakes
New brake lines perhaps?
Old Nov 13, 2004 | 12:58 PM
rnjohnson's Avatar
How do you feel the brake lines would cause that?
Old Nov 14, 2004 | 06:20 AM
01xtreme's Avatar
I'm not a brake expert or anything but my suggestion is to just take it to a brake shop and have them look at it. It could be your caliper messing too....they should be able to help you out (I hope). Like I said, I'm not an expert, I'm just trying to give some suggestions. Sorry.
Old Nov 15, 2004 | 03:19 AM
rnjohnson's Avatar
I'm sorry, there was no offense- I was just wondering what your specific thought was.
Old Nov 15, 2004 | 05:07 AM
01xtreme's Avatar
Don't worry about it. No offense taken, no defense given. [sm=icon_cheers.gif] Hope you get the problem solved.
Old Nov 15, 2009 | 10:32 PM
krybrn's Avatar
krybrn is on a distinguished road
Default sticky brake answer
Had a similar problem on an old ford pick up I had. Turned out to be a bad caliber. Hope this helps
Old Nov 15, 2009 | 11:27 PM
treysanatomy's Avatar
treysanatomy is on a distinguished road
GM hoses of that age are famous for breaking down internally causing many dfferent issues. I had a fullsize truck with same problem and 2 new hoses at 16 a pc solved it good luck
Old Nov 16, 2009 | 08:39 AM
mr.vls's Avatar
Do you have disk or drum brakes? If it is drum brakes I would replace the wheel cylinders and flush the brake fluid at the same time.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
dbo98
16
Aug 23, 2005 10:51 PM
